pro charger super damper
Old Apr 17, 2011 | 06:51 PM
lbm13186's Avatar
Default pro charger super damper
to connect to super damper & pulley to the crank all you need is the harmonic balancer and a pining kit correct??
Old Apr 17, 2011 | 08:17 PM
lbm13186's Avatar
or is there a hub that i have to get that goes to the damper???
Old Apr 17, 2011 | 09:09 PM
Aster's Avatar
The super damper comes complete. It is usually a three piece design with the hub and the two pieces for the ac belt and the main drive belt.
A pinning kit or key way will be needed for boost, and of course get a new crank bolt.
Old Apr 17, 2011 | 09:14 PM
lbm13186's Avatar
thanks alot man i bought a ket of a guy and he shipped it in a crate and when it got here it was in box's and stuff was missing so im trying to see what was all missing and what i need to get stuff working.
the guy that i bought it from side there was a scde cone or something that was really good it was aluminum and i guess he said it coast $800 but didnt remember where it came from?
but if i get a super damper it will have everything that i need to connect it to the crank?
and ya the shop is going to pin it to the crank he is waiting on me to give him the stuff kinda crapy.
Old Apr 17, 2011 | 09:24 PM
Aster's Avatar
SDCE made a crank pulley with an adapter to connect it to the stock balancer. Works for small boost, not recomended for more than that. The down side is the SDCE pulley is smaller so you have to use a smaller head unit pulley to make up for it which in turn leads to more potential for belt slip if using the stock procharger bracket design.
The question is if the kit you bought includes the whole SDCE bracket or not. If he paid that much though it sounds like it should be the whole thing. Does the bracket include a tensioner?
Old Apr 17, 2011 | 09:38 PM
lbm13186's Avatar
yes it did and that is really the only pulley that i got and im trying to make a list of everything that ups is going to pay for / get me on the road
Idler pulley- $85
8 rib aluminum crank pulley
8 rib super damper
Pro charger filter
Head unit pulley
Balancer
Air Box
3.5 flex-hose for Iter-cooler
3.5 metal coupler (ats561-3)
belts to go w/ all pulleys
if you think of anything i might b missing form the ket please let me know so i can check the bypass value and fuel line was there (even know i went with a lonnie kit) i shouldnt need the fuel stuff in the kit right??
so far this is what i got and bob said this should get me going
Old Apr 19, 2011 | 05:15 AM
Bob@BruteSpeed's Avatar
LS1Tech Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
Idler pulley- $85
8 rib super damper
Pro charger filter
Head unit pulley
Balancer
Air Box
If you have the SDCE J Bracket it will have a spring loaded tensioner on it. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
