LME Motor dynoed and shipped
Old Apr 19, 2011 | 04:27 PM
robsquikz28's Avatar
Lookin good Andy. SOmeone wants to win KOTS this year huh? lol
Old Apr 19, 2011 | 05:08 PM
02WSSICK's Avatar
Originally Posted by LASTLS1
I'm not sure what the turbos will make, I'm thinking around 30-32? At 19lbs it will run 7.9's all day long. I need to get the traction worked out and see what it's made of.
are you running presicion billet 76's?, if so, what ar? thanks
Old Apr 19, 2011 | 05:40 PM
LASTLS1's Avatar
6 Second Club Moderator
Standard wheel, .96
Old Apr 19, 2011 | 07:39 PM
LASTLS1's Avatar
Kots is all about traction, not power. That's a tricky race!!! Most of the cars that race in that have too much power. lol
Old Apr 19, 2011 | 07:42 PM
Phil99vette's Avatar
7 Second Club
Did you say something about Madman and CO? LOL!
Old Apr 20, 2011 | 08:31 AM
LASTLS1's Avatar
This race in on a unprepped scraped track. No track prep or burnouts past the starting line. No test runs, right off the trailer on a cold track. Like I said it's tricky to say the least. Yast year I took second with 17lbs of boost at a ramp rate of 8 psi per sec. lol
But I can tell you the first time out with drag radials I went my best 60' ever, including slicks. That was with one phone call to the Madman. I also finished second last year at that no prep race with his advice. Second place paid $4k cash.
Old Apr 20, 2011 | 08:51 AM
7 Second Club
So what your trying to say is Madman knows his SH*T. Brian is an animal when it comes to the suspension. Best of luck with the new motor!
Old Apr 20, 2011 | 09:05 AM
LASTLS1's Avatar
Thanks luck never hurts! YES Brain is the man!! Btw, thanks for your help on the phone, I can't wait to get the car out and try what we talked about with the controller.
Old Apr 21, 2011 | 07:32 AM
Clean94Z's Avatar
What's the turbo setup?
Old Apr 21, 2011 | 09:30 AM
LASTLS1's Avatar
Twin percision 76, 427
Old Apr 21, 2011 | 10:28 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Finally. Too bad the engine wasn't in sooner might have had everyone covered in Atlanta.
Let me know when you make plans for the track, I'll come out. We need to film all the passes I'm sure you'll crank off some 7.7's if the track holds.
Old Apr 21, 2011 | 02:04 PM
  #32
LASTLS1's Avatar
A big crate just came in that says TOP HEAVY!! lol I like my women top heavy not my motor. lol
Old Apr 21, 2011 | 02:22 PM
  #33
LASTLS1's Avatar
What torque did it make?
4000 and above it was 458. It peaked at 545@6100rpm. It made 662hp @ 6700 rpm. They didn't run it up very high. On boost I run it to 8500rpm.
Old Apr 21, 2011 | 02:25 PM
  #34
Clean94Z's Avatar
Damn thats turning that bad boy? Do you have stock LS7 casting?
This is a trans am right? whats you race weight?
Old Apr 21, 2011 | 02:50 PM
  #35
LASTLS1's Avatar
Yes it's a TA. 3525lbs last year in Kentucky. ET heads.
Old Apr 21, 2011 | 04:11 PM
  #36
Clean94Z's Avatar
does the car have alot of weight reduction or is it a full weight street car?
Are they true 6 bolt heads
Old Apr 21, 2011 | 05:11 PM
  #37
LASTLS1's Avatar
Yes weight reduction. Yes I think, what's a fake 6 bolt head?
Old Apr 21, 2011 | 06:00 PM
  #38
Clean94Z's Avatar
spool,race brakes,nothing behind the dash? what point cage?
what do you weigh?
I thought the stock heads were 4 bolts per cylinder. Then if you added the tables for the outside bolts it went to 5 per. I thought the 6th bolt was above the cylinder. Casted into 6 bolt heads. Im probably wrong
Old Apr 21, 2011 | 10:11 PM
  #39
LASTLS1's Avatar
what do you weigh?
ET LS7 6 bolt heads. 25.5 cage, race bakes, spool, it's a track car.
Old Apr 22, 2011 | 08:36 AM
  #40
Clean94Z's Avatar
Well its nasty as hell!!! I saw the KOTS videos!!! WICKED JUST PLAIN WICKED!!
