Exhaust sounds terrible.....
Old Apr 19, 2011 | 07:43 PM
salemetro's Avatar
Default Exhaust sounds terrible.....
HELP! I just recently fired up my newly-completed t-76 fed 5.3 project, and the exhaust sounds like an old POS Ford pickup(with crappy glass packs)!
I used 3" stainless that goes over the rear axle and splits into 2 three-inch Spintechs. It sounds good, until it's under load....then it just gets rude sounding. I'll try to post a video here later to help illustrate what I'm talking about. I just ordered a Vibrant 3" "ultra quiet" resonator, and am hoping that this will help mellow it out a little.
So, I'm wondering what types of exhaust setups have been used on single-turbo cars that will keep the tone more tolerable without causing too much restriction for a car that is aiming for 15psi. Any ideas??
Update: added video link...
http://www.youtube.com/watch?v=rLCilTCV0qw
Old Apr 19, 2011 | 08:52 PM
kmracer's Avatar
your problem is the chambered mufflers.. get rid of them. not only do they sound like ****, they're holding back your combo even with 2.
Old Apr 19, 2011 | 10:28 PM
turbo iroc's Avatar
Most ls motors are raspy sounding but I can imagine yours. Sounds like cherry bomb mufflers right? I hate that sound as well. I'm running the adjustable borla exhaust with the plates with different sized holes to bypass the muffler and control the sound. I have it all going thru the muffler. Prrs like a kitten, smooth mellow tone cruising, no resonance whatsoever. Its kind of restrictive that way tho and one tail pipe does nothing at all. BUT I have an electric exhaust cutout up front under the passenger floor. Best of both worlds, sleeper quiet or drag race open headers!
Old Apr 19, 2011 | 10:32 PM
salemetro's Avatar
Suggestions then?? I thought that all mufflers were "chambered", other than glasspacks/resonators? Kinda pisses me off that I spent so much on having these built, only to find that for some reason they sound like crap on my car. I've heard other cars (N/A) that sounded pretty damned good....so I'm kinda at a loss here.
See updated first post for video link....
Old Apr 19, 2011 | 10:38 PM
turbo iroc's Avatar
Borla or magnaflow sound the best imo.
Old Apr 19, 2011 | 10:39 PM
skyhighsami's Avatar
no title here
Magnaflow or Borla. Or add a glasspac/resonator
Old Apr 19, 2011 | 10:52 PM
salemetro's Avatar
I ordered a resonator from Vibrant Tech yesterday...I guess I'll wait and see how it sounds after that.
Old Apr 20, 2011 | 01:38 AM
kmracer's Avatar
you need to remove the chambered mufflers, period. things are entirely different with a turbo setup. you really only need a small muffler with a turbo setup anyways, and it needs to be straight through. run it with no mufflers and you'll see what i mean.
Old Apr 20, 2011 | 02:22 AM
salemetro's Avatar
Actually, I ordered 2 resonators (one for another project). Do you think that I'd be better-off replacing the spintechs with resonators? If not, what style of mufflers do you think would work best? People have mentioned Borla and a few others....but aren't those chambered as well? I just want to be done with this problem.
Thanks for the input.
Old Apr 20, 2011 | 03:57 AM
kmracer's Avatar
a single 18" resonator should be fine, or even the 12" if thats what you ordered. if its too loud, just weld in another.
Old Apr 20, 2011 | 05:54 AM
Nitroused383's Avatar
Dynomax ultra flow, magnaflow race mufflers, hooker maxflow, dynatech or borla xr-1. Lots of mustang guys like dynomax ultra flow ss mufflers. That vibrant resonator won't do much.
Old Apr 20, 2011 | 06:15 AM
HydroStream6's Avatar
I have a full 3" exhaust after my turbo and the only thing quieting it is a 3" resonator. Sounds perfect. I ran it without the resonator at first, and while it sounded great at idle, it popped and rasped like hell soon as I got over 2200.
Old Apr 27, 2011 | 09:14 PM
xcoldricex's Avatar
please post vids after you add the resonator, would like to hear how it changes the sound
Old Apr 27, 2011 | 09:21 PM
tripblackls1's Avatar
so far i really like the sound of my car with single 4" dynatech spiltflow
Old Apr 27, 2011 | 10:58 PM
98Z28CobraKiller's Avatar
Restricted User
Here's my setup from the back. It's a mandrel 4" with a 4" MagnaFlow then over the axle and capped as seen in the completed picture below. It "T"s of 3" thru a 3" Borla XR1 and out the drivers side. VERY Quiet. I have run 9.31 in the 1/4 with it capped on 17 psi.
The pump has been relocated.
Old Apr 28, 2011 | 08:33 AM
slow00gt's Avatar
Im running single 3.5 mandrel bent from turbo back with a 3.5 dynomax bullet. Doesnt sound too bad
