What victor jr. Should i buy?
What type of TB setup do you wanna run, elbow to the front or topmount accufab type with a carb hat?
The vic series require their own style fuel rails as well. Also a TB cable mod/replacement.
Also do you have an aftermarket hood? its quite damn near impossible to get a vic intake setup to clear the stockers if i remember right
would anyone know what would be the part numbers for the tb, fuel rails and other parts to convert it to a vic jr?would appreciate any help.
you either need an accufab 4150, or en elbow w/ an elbow and 90mm TB mount, but that intake with an elbow and a 90mm like that really pry wont get you very much.
post the rest of your setup (motor spec wise) and someone will be able to help you
I didnt cut ANYTHING to make it fit, but it did touch the hood a tiny little bit. a few months later, i cut a small piece off the inside of the hood so it wouldnt touch anymore, but that was only for cosmetic reasons.
if you have an aftremarket cowl hood with lots of room, you can get a taller elbow that will flow a little better. But you will need to cut part of the plastic cowl if you do that.
would you happen to have the part numbers for these parts?i would really appreciate if you would give me the part numbers or just pm me the part #'s
Fuel Rail Kit: 3638
ultra-low elbow: 3847 (38473 in black)
competetion 90mm throttle body: 3864 (38643 in black)
Yeahhhhhh
SO you still havent answered. How much clearance do you actually have for a proper elbow ?
