which supercharger to get....
Old Apr 20, 2011 | 01:03 AM
Chaos07's Avatar
Default which supercharger to get....
ok guys later down the line ill be transplanting an Lq9 into the TA with H/C/I and all that stuff. Anyway i have been looking into the Procharger system and was wondering if there were any other superchargers out there availble for the F-body...i want to know reliablitly and performance. Thanks guys for the input
Old Apr 20, 2011 | 01:37 AM
Ericmck2000's Avatar
Well, After owning a p1sc for a couple years. I kinda wish I would have went with the F-series..... Or went with a quality turbo setup.
Old Apr 20, 2011 | 01:53 AM
Chaos07's Avatar
How did the P1SC treat you, good or bad?
Old Apr 20, 2011 | 05:36 AM
Clyde H Frasier Jr's Avatar
How much boost are you trying to make? D1sc is good to about 13-14 lbs.
I have a 02 camaro with a d1sc making 13 lbs of boost.
Old Apr 20, 2011 | 05:51 AM
Bob@BruteSpeed's Avatar
LS1Tech Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
I recommend going with the ProCharger D-1SC pn# 1GJ204-SCI. This is the upgraded 8 rib belt system with the upgraded 4.5" twin intercoolers. The D-1SC works awesome at 8 psi for stock engines and also work great at higher boost levels. At the old shop we had a Corvette 346 at 16 psi of boost with a D-1SC/740 rwhp running on a road course for several hard seasons. The pn# 1GJ204-SCI requires additional parts such as an aftermarket harmonic balancer, fuel injectors, fuel pump, etc and I have put together a complete system that can be seen at this link. http://shop.brutespeed.com/ATI-1GJ20...-Speed-Kit.htm
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Old Apr 20, 2011 | 06:40 AM
LS1RedZ's Avatar
Procharger, if you want a good reliable setup. I have a D1SC setup on a 370 and havent had any problems with it.
Old Apr 20, 2011 | 08:14 AM
93formto98T/A's Avatar
I'd also recommend a procharger D1sc for your setup.
Old Apr 20, 2011 | 09:09 AM
Aster's Avatar
A lot depends on how much power you want to make. I've had both the P1SC and a D1SC and I should have just bought the D1 to begin with. Instead I had to do it twice because I bought a used head unit that was too small and couldn't handle the motor I built behind it.
The D1SC isn't really much more expensive than the P1 and it really is a much better head unit. My D1SC at 13 psi puts out cooler air than my old P1SC at 9 psi.
 Michael S. Palmer
Old Apr 20, 2011 | 03:48 PM
Chaos07's Avatar
thnks guys, when the time comes ill hit you up bob for details on doing the supercharger kit sounds like procharger is a good relaible unit
Old Apr 20, 2011 | 04:30 PM
InsaneDomestics's Avatar
You say LQ9, would that be stock cubes, or would it be bored to bigger cubes? How much power are you tryin to make and how much boost?
Old Apr 20, 2011 | 04:35 PM
Chaos07's Avatar
402ci and i would probably want to get into the 500 HP levels and maybe keep the boost at 8-10 psi i dont want to really blow anything up
Old Apr 20, 2011 | 05:10 PM
ChevyChad's Avatar
8 sec potential, 12 sec slip
+1 for procharger. I've been running prochargers in my cars for about 11 or 12 years. Never had a problem with any of the head units I've had. Had 2 bearings go out in idler pulleys, but thats it.
Old Apr 20, 2011 | 07:48 PM
The p1sc treated me excellent. Very perdictible powerband, and after owning it for a couple years, the only times I have had to touch it... was to change the oil in it.
But, When you want to make more power.... It starts falling behind at 500-650rwhp.
But, as everybody else in this thread has said. Start with the D1. I think its like a extra 300$ or something. Works more efficient as well.
500hp for the d1 will be easy. Im aiming to make 600rwhp with the p1 as soon as all of the parts arrive...
Old Apr 21, 2011 | 10:09 AM
Aster's Avatar
If you're building a 402 it will be hard to only make 500 hp. Hell you could make 500 N/A with that size motor. Why build a 402 and get a blower if you aren't aiming for more? You can do 500 all day long on a stock motor with a blower at 8 psi. 8 - 10 PSI on a 402 is a lot more air that on a 346. You should easilly be in the 600's with that combination.
Old Apr 22, 2011 | 06:34 AM
LS1RedZ's Avatar
If you build a decent 402 then you wont have to worry about blowing it up at 500hp. Plus you would have to run like 3psi to reach that power level lol.
