Need a opinion on the setup
Old May 1, 2011 | 01:08 AM
HOT Z28's Avatar
Default Need a opinion on the setup
Here is the perdicament Im in, I built my engine to be NA and maybe some nitrous, now I came across this very nice complete turbo kit.
Mine compresion is around 11:1 with 90mm fast intake and ported and milled ls6 heads. I was wondering how much boost (if any) I can put at it on pump gas and how much on race gas. Also my car is a 98 so is tuning going to be an issue?
Any input will be appriciated
Old May 1, 2011 | 09:05 AM
Bob@BruteSpeed's Avatar
LS1Tech Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
Back at the old EPP shop we put 7 psi of turbo boost to an 11.0/1 combination, we added methanol injection to it and it ran great. Not sure how much more boost you could add with race gas. The '98 computer can get it done with a good tune. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Old May 1, 2011 | 09:12 AM
HOT Z28's Avatar
By any chance do you remember what kinda power it was making. I know that my cam is for NA aplication and it will make a big difference if I swap it, but for now I just want to know the ballpark figure. Thanks for your input.
Old May 1, 2011 | 09:14 AM
LS1Tech Sponsor
Thumbs up
It was at 700 rwhp and it pulled like a freight train. Bob
__________________
Old May 1, 2011 | 10:07 AM
98TA6.0's Avatar
the high compression will help spool and make good power out of boost but it will limit you when you wanna turn the boost up later. i ran 8 lbs on my 11.4:1 AFR headed (58cc chambers) and made "better" power than when i moved to ported 317s later (72cc chambers). although with the 317s it allowed me to turn it up to 16 psi. for street driving the higher compression was more friendly and less abrupt. what do you plan to do with the car then make your decision.
Old May 1, 2011 | 10:09 AM
HOT Z28's Avatar
WOW thats all i needed to know.
Sorry to pick your brain like that but I have 60lb siemens deka injectors, do you think they be big enough?
Old May 1, 2011 | 10:44 AM
98TA6.0's Avatar
60s will do fine. i used them on my ble car and made over 700 hp. they are pretty much maxed out after that. another route you could go to help combat detonation would be E85.
