help on turbo setup
Old May 1, 2011 | 05:58 PM
ls1curt's Avatar
Default help on turbo setup
hey, im planning on switching to boost soon. heres what i plan on running. let me know how this setup sounds and if you guys think i should change anything.
engine:
ls1 aluminum block
383 stroker- forged eagle crank/rods forged arias -3cc piston
317 heads slightly ported with good springs compression will probably be around 10.5
arp studs throughout
ls9 headgaskets
custom turbo cam- whatever slowhawk wants to spec me
victor jr w/ sheetmetal elbow and 90mm tb
twin walbro 255's and 83lb injectors
turbo system:
truck manifolds
pt 88 .96 ar
precision 46mm wastegate
turbosmart 50mm bov
ebay fmic
meth
drivtrain:
th400 w/ yank turbo spec stall
12 bolt w/ 3.42's
How does this sound? im looking to put out around 700whp or trap 145+mph on pump w/ meth.
thanks
Old May 1, 2011 | 06:33 PM
evo462's Avatar
It sounds pretty badass!
Old May 1, 2011 | 08:57 PM
sho-me speed's Avatar
Closed ex-Sponsor Account
twin 70's will make 700rwhp on very little boost.
Old May 8, 2011 | 03:14 PM
ls1curt's Avatar
think im going to go with a big single 88 instead. what injectors do i need? low imp or high imp? will 2 walbros be enough or should i go with 3? will a 46mm wastegate be big enough?
