what stall should i use??????
Old May 4, 2011 | 06:39 PM
gallo-lo's Avatar
Default what stall should i use??????
im building my 99 z28 ,5.3L 317heads,z06cam,intake,arp studs, 80lbs inj, t-72 96ar t-4 12lbsboost max.im goin with th400 and im about to start lookin into a torque converter,should a 3400stall work with this set up?i have 3.73 gears i was looking in dropping to 3.23 or 3.55 gears on a 28tall tire.
Old May 5, 2011 | 04:46 AM
gallo-lo's Avatar
Anybody?
Old May 5, 2011 | 02:33 PM
AutoRoc's Avatar
3000-3600 will work great. You won't have any problems spoiling that turbo if that's what you are worried about. Yank or PTC can set you up right.
Old May 5, 2011 | 02:39 PM
98Z28CobraKiller's Avatar
Restricted User
Call Greg at FTI http://fticonverters.com/
Make sure you have the weight of the vehicle, the actual gear that you intend to run and a good realistic estimate of how much power. I would go for something in the 4000+ RPM stall range. His converters are tight when you're driving around so you wont be able to tell it's a 4K stall until you stab it.
Old May 5, 2011 | 03:21 PM
van383's Avatar
tim or lane at ptcrace.com tell them i sent you..
Old May 5, 2011 | 07:36 PM
gallo-lo's Avatar
thanks guys!
