turbo setup, engine, and timing
Old May 9, 2011 | 08:06 AM
cleonard's Avatar
Default turbo setup, engine, and timing
im going to be building a 6.0 iron block with compstar 6.125 rods and diamond pistons which cc with factory heads would work best? also need to choose size of turbo, and what would be a base timing to start with on pump gas?
Old May 9, 2011 | 08:24 AM
Fireball's Avatar
what piston you going with? stock stroke? the dish of the piston of the piston will dictate the head cc...
Old May 9, 2011 | 09:20 AM
cleonard's Avatar
stoke stroke, diamond pistons just unsure of dish size.
Old May 9, 2011 | 09:30 AM
Fireball's Avatar
dish size + head cc together dictate your compression ratio.
Old May 9, 2011 | 09:41 AM
cleonard's Avatar
what compression ratio would you suggest staying at on a street machine
Old May 9, 2011 | 09:53 AM
Fireball's Avatar
9:1, give or take
Old May 9, 2011 | 11:05 AM
cleonard's Avatar
thanks for the info.
