polishing impeller wheel
Old May 10, 2011 | 05:02 PM
dwnshft82's Avatar
Default polishing impeller wheel
OK my p1sc-1 inner and outer seal's are leaking. I pulled the unit apart to replace theme and found the impeller is rather ruff. The impeller housing is cast in 2 piece and has a lot off imperfections in it. Would it be worth it to polish thees parts or can i damage the air flow.
I no the part number of the seal behind the pulley skf-11625 or cr-11625
anyone no the seal part number behind the impeller
thanks four any help
Old May 10, 2011 | 05:20 PM
cracker's Avatar
Dont touch it.
Old May 10, 2011 | 07:13 PM
madmax4499's Avatar
+1 you wont gain anything, there is a reason they are leaking, check it all out. or it might wipe out the new seals. Im no expert.
Old May 10, 2011 | 10:30 PM
99_LS1_WS6's Avatar
Depending upon the turbo you have there are a brass bushing inside the intake side that wears and can let it leak.
Old May 11, 2011 | 01:34 AM
STEEPSS's Avatar
Not ball bustin, but its a turbo on a stick brah
Old May 11, 2011 | 02:17 PM
dwnshft82's Avatar
yea i think i will leave it alone and i will inspect all the bearing's when i have it apart. to see if there is anything obvious that might cause the seals to go bad. The outer seal is bad because the last owner used a screwdriver to remove the pulley and dented the seal frame.
