STS Questions
This is a very rough calcuator you can use if you dont know all of the info.
http://www.eastcoastrollingthunder.c...r/finject1.htm
im also thinking of going with forged rods and pistons. i found a good priced set of wiseco -15cc 3.903 bore pistons and im trying to figure out if it is a good set for what im wanting to do. i know i will need to bore out my block (really dont want to do that) but i havent found a decient set that will go in the stock bore
check out my build. make sure to get a ball bearing turbo.
I think I have the measurements in my thread somewhere for the max size you can mount an IC in-between the fog lights. as far as STS... I'm not sure on their scavenge pump, they may have a better one now, I know the kit has gone through several revisions.
PCV... yeh catch can. I even went as far as venting the oil fill cap & venting through the newer LS6 center valley & venting the driver side rear valve cover.
