turbo oil drain?
Old May 17, 2011 | 09:29 PM
70c10's Avatar
Default turbo oil drain?
Can I place my oil return line on the pass side of the oil pan. I thought I read somewhere its better to place it on the filter side. I cant do that because my turbo is mounted on the pass side and the angle for the drain would be bad. thanks
Old May 18, 2011 | 10:51 AM
XtremeDime's Avatar
Im pretty sure the oil pan is symmetrical so you should be able to place it on either side. Id avoid having it around that sensor(I think its oil level?) though.
Old May 18, 2011 | 11:22 AM
Compressor Surge's Avatar
It will be fine on the PS of the oil pan.
