Installing meth today..is this an ideal place?
Old May 21, 2011 | 12:25 PM
Snyper's Avatar
Default Installing meth today..is this an ideal place?
The IAT is already installed in this location(in yellow) and I was thinking about placing the nozzles on each side of the pipe(in red) as shown in the picture. They are 2 M7 nozzles, so they should atomize really well. I figured this would be far enough back to cool the incoming charge, and also register on the sensor so I could add and pull timing with the temp change. I didn't want the nozzles too close to the IAT. Also, I will be running a 33/66 meth/water mix(1 gal of M1 to 2 gal dis.water)
Old May 21, 2011 | 12:27 PM
blue00ZZleeper's Avatar
That looks perfect. They say 6" from the throttle body is best but that should be just fine.
Old May 21, 2011 | 12:30 PM
madmax4499's Avatar
are the m7's 700cc each?
Old May 21, 2011 | 01:16 PM
Snyper's Avatar
No idea.
Old May 21, 2011 | 01:51 PM
ChevyChad's Avatar
8 sec potential, 12 sec slip
Is it okay to have the meth nozzles placed before a 90° turn like that? I always thought it was recommended to have a straight shot into the manifold?
Old May 21, 2011 | 02:25 PM
Snyper's Avatar
Yes. Im using 2 small M7s at high pressure. You don't want to get too close to the intake manifold(from what im told) because you wont have equal distribution to each cylinder. Plus having them further away allows the meth/water to cool the intake charge air.
Old May 21, 2011 | 07:43 PM
boosted LT1's Avatar
Best is always debatable but here is what one company has on line
http://www.alcohol-injection.com/art...tion-nozzle-2/
I put mine a lot closer to the TB, it works for me hope yours works good for you
Old May 21, 2011 | 08:28 PM
Snyper's Avatar
Tried it tonight and it works great. Temps and AF dropped really quick. I have it set through my boost controller to turn on at 9.7psi. Immediately the IATS dropped along with the AFR. Im going to do some tuning tonight to see what I can get out of it. The owner of the company I bought my kit from said putting it before one 90* would cause no issues. Also where I have it, the meth has more time to better cool the intake charge coming in.
Old May 21, 2011 | 09:01 PM
I love how meth lowers the temp. I run close to ambient which helps fight detonation
Good luck
Old May 22, 2011 | 01:58 AM
Snyper's Avatar
How quickly does your sensor respond to the meth?
Old May 22, 2011 | 04:35 AM
Packy's Avatar
That is exactly how I did mine except I only have one nozzle.
Old May 22, 2011 | 07:36 AM
The temperature reacts immediately since mine hits injection point quickly I really don't dop temperature as much as never having the temperature rise.
Old May 22, 2011 | 08:17 AM
turbo 408's Avatar
What mods did the Vette have that you went up against in your video
Old May 22, 2011 | 09:02 AM
If that question is for me...I went ~7.8 1/8 on that pass the engine back fired ~150 foot mark and I coasted. You can hear the engine backfire and me pull out if you listen closely
Old May 22, 2011 | 09:45 AM
turbo 408's Avatar
Talking about snyper on his YouTube page sorry
Old May 22, 2011 | 11:54 AM
Snyper's Avatar
That makes sense. At first I wasn't sure if it was working. The temp would start to rise sharply(as usually) then level out(not normal) and as soon as id let off the throttle the temp would drop hard.
Old May 22, 2011 | 02:02 PM
A friend swears mine isn't working and only 'fooling' the IAT sensor. I believe it makes the air denser (cooler) and helps prevent detonation (octane). As for how much, I push where I would without and feel that leaves me some margin.
Especially if the meth fails I shouldn't melt. With boost you never have enough margin, but I believe meth gives us a little so to me it is worth it.
Others turn it up more with meth and that's cool just I prefer to increase detonation safety. I use Blue windshield wiper fluid with one can of yellow 'Heet' that seems to make the gallon flammable. There is a big debate on the mixture as well
Thanks
Old May 22, 2011 | 02:39 PM
Snyper's Avatar
Im using a 50/50 mix of M1 and distilled water.
Old May 22, 2011 | 04:25 PM
I think thats a good mixture I use the wioer fluid for ease of find etc. I think our mixtures are very close to the same.
Old May 22, 2011 | 10:22 PM
Snyper's Avatar
Well it seems to be working pretty good. I only had the boost up to 12psi so far but one thing I notice is the IATs still rise but slower..and whenever I shift, they shoot down. then start to go back up again.
