Fuel system question
Old May 22, 2011 | 05:37 PM
badss_02's Avatar
Default Fuel system question
Hey guys I'm in the middle of a build and new to the FI scene... I have an 02 ss camaro that i'm currently building an iron ls1 for (oversized 5.3l). Not only am i new to the whole turbo thing but i also plan on running e85 on it. I'm almost through with the build except for the fuel system... The only thing im dead set on is the car making at least 1000 to the wheels. What are some suggestions on the line size, fuel pump (or pumps) and injector size?
Old May 23, 2011 | 09:52 PM
badss_02's Avatar
Nobody has any idea? Guess I don't feel so stupid now...
Old May 24, 2011 | 12:14 AM
droksformula's Avatar
I too am specing a 1000+rwhp e85 fuel system right now.
There's actualy a lot of options out there right now, its basicly just a balance between simplicity, price, noise. Your always going to want to go faster after while so its best to build with room to grow if you can afford it.
Guessing its a street car with stock ecu, best choice would be injector dynamics 2000cc(expensive, but the best) for injectors, second choice, something from fic's catalog, 120lb, etc.
As for pumps, there's even more choices. If you have an ati crank dampner, you can run a belt drive fuel pump. Or if you want to stay electric there's weldons 2345-a (noisy), twin bosch 044, magnafuel 4303(mixed reviews to if it will push 1k on e85)and 4703(streetable ?).
Use a good size fuel cooler, and there's nothing wrong with stepping up to the next size fuel line that the pump calls for, both on the inlet and outlet. And be sure to use pre and post filters.
And I'm sure they all work, but I hear nothing but good stuf about weldons fp regulators.
Hope this helpes, Derek.
Old May 24, 2011 | 07:17 AM
LS1RedZ's Avatar
Give Lonnies a call, he can hook you up with whatever you need. Id say get his dual intank pump kit with all of the necessary lines, rails, etc. His kit is extremely user friendly and you can install it yourself.
Old May 24, 2011 | 07:45 AM
LS1NOVA's Avatar
Lonnies dual pumps wont make it to 1000.(on E85) You will need three Walbros.
DroksFormula hit most of the points. Im using a 4303 on a GTO Im building, looking for 1000 also.
FIC has the same high impedence injectors as the ID2000's but lots cheaper.
Id recommend -12 to the pump, -10 feed, return, and vent. Some sort of cooler on the return. Derale makes some nice coolers with 1/2" npt fittings.
What turbos you running?
Old May 24, 2011 | 06:19 PM
Lonnies Performance's Avatar
LS1TECH Sponsor
Feel free to give me a call concerning a fuel system for your application.
There are a lot of variables to discuss & getting 1000 streetable RWHP on E85 is not trivial. Considering you have a 5.3, you need to be careful on injector size. 2000cc will give you idle issues, even on E85.
Old May 29, 2011 | 11:32 PM
badss_02's Avatar
I will give you a shout tomorrow... Maybe you can help me make some decisions. Thanks!
