"Stand Alone" Meth Tank?
Old Jun 4, 2011 | 09:05 AM
whiteboycntdnce's Avatar
Default "Stand Alone" Meth Tank?
Due to some over heating issues with the car, I'm going to relocate the battery to the back of the car, and move my methanol tank to the stock battery location. My question is, does anyone know of any companies that make a "stand alone" tank for methanol? Thanks
Old Jun 4, 2011 | 10:16 AM
BadgeZ28's Avatar
Why not use a universal coolant recovery tank? You could also hit the junk yards and find a factory tank that would fit the battery space.
Old Jun 4, 2011 | 01:25 PM
dschmittie1's Avatar
Seeing that frost Tunes your car I am sure you have a Alky control kit. Call alky control they modify JAZ fuel cells for use as a Meth tank.
Old Jun 6, 2011 | 10:26 AM
Turb0Z28's Avatar
This is the one i have in my battry tray.
coolingmist ShurTank
Old Jun 6, 2011 | 03:41 PM
stevieturbo's Avatar
Alcohol injection systems make a superb tank. Pump mounts underneath the tank and hidden within.
I just got one today. The design is good, and in real life it's equally as good. Would definitely recommend it
Old Jun 7, 2011 | 07:06 PM
TTT...
I should have mentioned this originally, yes I am currently running the Alky Control kit with the standard washer fluid tank. I believe the only other style tank offered by them is one that is put in the trunk. Turb0z28, when I google that name tank all I see coming up are trunk mounted tanks... Do you have a direct link to the tank you're running? Thanks!
