turbo cam question. specs inside
Old Jun 4, 2011 | 01:29 PM
86MonteSS's Avatar
Default turbo cam question. specs inside
motor is a forged LS2 (stock cubes) with 9.5:1 compression.
Comp Cam
226/228 115 LSA .585/.588
intake grind #3723
exhaust grind #3724
Old Jun 4, 2011 | 02:05 PM
brianfromhawaii's Avatar
What is the question?
Old Jun 4, 2011 | 03:44 PM
86MonteSS's Avatar
Oops. Haha.
How well will this work? I'm shooting for 700 rwhp on low boost. 1000+ when I turn it up.
Old Jun 4, 2011 | 04:01 PM
tripblackls1's Avatar
what turbo? heads? intake? car its going into(weight)? auto or stick? and gears?
there is alot that goes into spec'ing a cam
but the cam you posted does look to be fine for a turbo car (more intake dur would help) but does not mean it will be good for your car
Old Jun 4, 2011 | 04:43 PM
Fbodyjunkie06's Avatar
C.I.? I'm guessing 364? Heads? 243's? 317's? Turbo? Tranny? Rear end?
Old Jun 5, 2011 | 12:46 AM
86MonteSS's Avatar
364. Unported LS2 heads. Ported LS2 intake. Precision 6265's. .58 AR T4. 99 FRC. Probably 3200 pounds. t56. 3.73 in it now, but will drop down to 3.42 or 3.15. Haven't decided on that yet. E85 (if it matters). Won't be revving much past 6500
Old Jun 5, 2011 | 02:17 AM
slowlsx's Avatar
You can make your desired numbers alot easier with a little bit bigger cam or maybe a specific custom grind
