6-71 question
Old Jun 8, 2011 | 10:12 PM
Paul Bell's Avatar
That's MISTER MODERATOR
Default 6-71 question
My friend's '66 Impala has had a tough to find issue. We think we've narrowed it down to the base gasket.
The design of the base puts bolts around the outside of the base to bolt it down but the surfaces that need to be sealed are far from these bolts. The gasket appears to be clamping well around the bolts but not the inner section of the gasket. The surfaces appear to be properly machined flat.
On the gasket that was removed, the red areas in the front & rear look pretty poor. The back section looks like it's stretched a bit. The gasket is obviously bad.
Gasket pic (just a stock photo, not the removed one): Black areas well clamped. Red areas, not very well clamped. The red areas is where the clamping is needed the most.
My question: Does anybody make a better gasket such as a printoseal type gasket?
Old Jun 9, 2011 | 12:31 AM
68 SS's Avatar
Contact BDS they make a much better gasket than the others out there also use a good gasket glue on both sides had a similar problem on my old car with a 14-71.
Old Jun 9, 2011 | 07:13 AM
Paul Bell's Avatar
Thanks 68!
