APS Fbody Kando water lines VS stock APS
Ok so here is the scenario... I am having a dilemna with my new Kando Dynamic Centers for the APS Fbody kit. It is the cooling line routing and which ports are blocked off on the the housing. I am uploading a simple drawing of it, and I will try to upload actual pictures when I get the time. I didnt really want to re-route the water lines, but I guess I will if I have to.
But the main problem, is this: The factory APS center housings, where there is a water block off, the port is still threaded, and then there is a screwed in block off in it (GOOD!), on the Kando's, they had pressed in block offs, that are in to unthreaded ports (Bad!). So I didnt really find this all out until I took the Kandos to the machine shop to get the pressed in block off plugs removed. So I figured I could thread them no problem, but the thread size will be bigger than the other water ports, thus I couldnt reuse my bolts, and maybe my line ends would have to change too.
What would you guys recommend?
1. Stay with the way the Kando's come (Change water line routing)?
2. Fix it all up to the factory APS routing.
I think there are only about 5 Kando users on here, but what did you guys do with this? Thanks in advance for the help!
Good diagram btw...
