Turbo oil leak problem
Old Jun 28, 2011 | 01:10 PM
1lo94's Avatar
Default Turbo oil leak problem
So I have an 01 trans am and I just installed a sts rearmount intercooled setup on my car. It has stock turbo and stock sts oil pump, I started it up for first time Sunday night and took it for a text drive. Car starts building boost and seems to run fine, haven't gouged on it yet because I was goin to tune car tonight or tomorrow. Well I took car around block then brought it back into shop and checked it out, everything seemed great, I drove it up to gas station put gas in it, then drove it to the house, I noticed a little smoke when I was pulling up in driveway, so I killed car. Looked to have a little oil dripping around turbo area. So I let it sit overnight then started and moved it shop yesterday morning and put it on the rack and notice oil coming out exhaust side of turbo. Curious if anyone else has ran into this? I car hear scavenger pump, and the lines aren't leaking? Does the turbo sound like it needs a rebuild? Any help is appreciated
Old Jun 28, 2011 | 01:16 PM
XtremeDime's Avatar
Sounds like the scavenging pump isnt doing its job. Pretty common. It could be the seal on the turbo but I would bet its the pump
Old Jun 28, 2011 | 09:33 PM
massconfusion's Avatar
i ve heard that you need a checkvalve sometimes bc the pump wont suck the turbo dry. I have the same problem but dont know what kind of check valve to use or where to get it. anyone else know?
Old Jun 28, 2011 | 09:59 PM
Preston99WS6's Avatar
You can buy the check valve directly from STS I had the same problem and that fixed it the valve wasnt too expensive I bought one probably three years ago havent had a problem since.
Old Jun 29, 2011 | 09:19 PM
just ordered mine so i ll let you know if it helps bro
Old Jun 29, 2011 | 11:10 PM
1lo94's Avatar
i ordered one also, but then took my turbo off and it is trashed so i ordered a bigger turbo....so we'll see how this works out for me also
Old Jun 30, 2011 | 01:19 PM
BlackChicken's Avatar
I'm having the same problem, spitting out oil but the pump sounds like its on. I need to get it to the shop to see what the problem.
