help what springs should I get?
Old Jul 1, 2011 | 07:48 PM
70c10's Avatar
Default help what springs should I get?
I just purchased a tu1 cam from speed inc. Wondering if I should get pac1518's or prc's the cam specs are 225/225 581/581 113 lsa on a stock bottom 01 ls1. 70mm master power turbo. Thanks I need to purchase asap
Old Jul 1, 2011 | 07:52 PM
XtremeDime's Avatar
Just get some duals and call it good. I went with Lunati Golds, pretty much the same specs as patriot golds just a little cheaper.
Old Jul 1, 2011 | 08:13 PM
70c10's Avatar
Im looking at the dual precision racing components not the patriots. But the 1518's are cheaper and reuse the factory spring hardware. Will the 1518's give me valve float. Im only boosting 7-9 lbs
Old Jul 1, 2011 | 10:13 PM
yessir's Avatar
1+ for lunati
