STS turbo
definitely grab the 67mm version (that should be the base kit i would hope by now). you will make 500rwhp and tq with that setup.
stud the heads if you are going to run more than 7psi and make sure and run one stage colder spark plugs. The factory engine will be fine on 5-7psi NO MORE.
leave your factory manifolds on the car, wrap all of the exhaust from the junction at the front of the y-pipe all the way back, grab a turbo blanket and have some fun!
