RPM, boost, and engine life
The car made 594/533 on a dyno that supposedly reads 10%ish low compared to others in the area, I was told to be prepared for heart break numbers but instead my car produced really well.
Based on the research I have done I am on the high side of what is "safe" for boost and hp level on a stock bottom end. To aid this situation I have set my shift light at 5600rpm which results in a max boost level of about 8psi the aggread upon best max boost level for stock bottom end cars.
Now onto my question....
I am happy with the feeling even shifting early so wouldn't 8psi be easier on the engine at 5600rpm compared to the same boost level at redline? I could put a larger pulley on it but if this way is even safer I would like to keep the smaller pulley for a couple of reasons.
1) Boost comes in earlier at lower rpm compared to if it had a larger pulley thus is currently stronger in the midrange rpm than if I were to change the pulley.
2) If I do ever put meth on it I could probably run it to redline safely with the current pulley and still be safe on the engine????
So what do you think keep the current pulley and shift early? What are the cons I haven't thought of?
My personal car has seen well over 600 rwhp and 6600 rpm with 11:1 compression. Single walbro and meth, I have 128,000 miles on my car. It has hundreds of blast on it. Make sure your pcv system is setup properly to pull clean air from your air filter. My friends meth kit quit several times on his gto and the way I had the tune setup it never hurt the thing at all. Keep the timing low and the tune safe it will live.
I run an Alky control kit and it is a great setup designed for an f-body if you want to use your windshield washer reservoir. If you're in a bind and can't find any methanol just look for any -20 to -30 windshield washer fluid that doesn't contain glycol (anti-freeze). Throw a couple bottles of heet in and it should be around 50/50 water meth. You can look up the MSDS (medical safety data sheets) for the different brands of washer fluid to determine what percentage of methanol they have in them. It's honestly no big deal at all to double check it.
