return line question
Old Jul 13, 2011 | 07:48 PM
95batmobile's Avatar
Default return line question
im sure this has been asked a mess of times but i put my return line bung a little to low on the pan (right as i top off the oil its overflows out of bung) but i am running a scavenger pump throught 10an line... will i be fine even though its below the oil line? because i understand the concept with the gravity returns not being able to be under the line but when i have a force pushing through the weight of the oil in the line it should push right back into the pan and flow. right?
Old Jul 13, 2011 | 09:03 PM
bmppp
Old Jul 13, 2011 | 09:25 PM
hawk584's Avatar
mine is set up with the oil line to the turbo coming from a fitting above the oil filter and the return dumping through a fitting in the oil fill cap
Old Jul 14, 2011 | 05:14 AM
yea thats how i was going to do mine.. but i figued a bung would be better. till i put it too low.. i might be able to cap it off and feed the line all the way up to the oil cap
Old Jul 14, 2011 | 09:45 AM
madmax4499's Avatar
it will be fine, the pump is going to push the oil into the pan. what problem do you think your going to have?
Old Jul 14, 2011 | 11:03 AM
i was just making sure with all the talk about not having it below the oil line.. thats a relief tho
