STS turbo need help making boost
I really wish that you had more contact with the members on this board before you went out boosting.... Practically everything you did to decrease the spool time and up the pressure was terribly wrong. Make sure that when you get everything back together that you follow sound advice first. Last edited by 3800SII; Jul 22, 2011 at 03:21 PM.
You could put 20k in the new engine an it will still blow the same way the last did, your stock motor blowing had more to do with, tune and driver. How fast were you going when you decided to boost in 4th and 5th?
