trying to decide on a turbo...again
This is the first paragraph of the thread that was closed: I am in the process of building a forged 408 iron block for boost with stock 317's and victor jr. this is going through a m6. I am going to build a 1000rwhp car with no ac, battery relocated, alt relocated, coolant likely relocated, radiator verted, fuse box adjusted. I am doing all of this myself besides the shortblock assembly (wish me luck). This kind of sounds like i'm yielding a twin set-up right?
I'd go big single and spend the left over money on a large ci engine to spool it
Is it the cool factor?
Is it because you think they will outperform a single setup?
Do you have money for the extra **** TT will need?
Did you plan on doing "no ac, battery relocated, alt relocated, coolant likely relocated, radiator verted, fuse box adjusted" with a single turbo setup as well even if it does not require it?
pretty much just because i havent done one, lol
i dont mind the fab. work, just going in trying to get the correct turbo sizing
for mainly street, from what i have gathered, twins, or a single on the smaller side, maybe a touch higher comp., and def a cam ground for a turbo
this is just my thoughts, and i may be way off base
everyone will have a diff opinion, and thats where the confusion lies with someone just starting into this-door 1, 2, or 3, lol
They sell like 4-6 major brands. I know you aren't FI yet but I wouldn't hesitate to give Jose a call about turbo selection.
Twins there are a ton of options. Twin tc76, twin t70, twin Precesion 67's(I forget the number.
