Fuel Slut! AES 390 TT TC-70's AMC Javelin Build.
#61
Hmm, well first off what is the treadwear on them?
Honestly I'd look into a set of Hoosier QTP's, they are what Larry Larson runs on his "street" car that he wins drag week with every year and ran 7's with. He drove them in the rain, I wouldn't, he's a braver soul than me. They are a DOT slick that is pretty much a Hoosier Drag Radial with a Bias-Ply rubber compound, but offered in much wider sizes that you would need to keep that look you have on your car, and I'm assuming your wheels are 12"+ wide also.
#63
It runs. i started it to get my first heat cycle and drop the oil. PROBLEM! the passenger side head stud, outboard side is leaking water right up between the stud and nut. "it was leaking before i started it." the head stud holes are blind? right? I checked the exhaust manifold bolts and it is not leaking from them for sure it is the stud right in the middle. I will pull the manifold off and post a vid of it. im going to pull the valve covers and check the studs exposed to oil as well.
#64
The head studs are supposed to be blind... is it possible that the block cracked when you torqued the studs? On my first LS1 head install I put thread sealer on the head bolts and cracked the block but it didn't leak...
It is possible that the studs were bottomed out in the holes.
Either cracked block or bad head gasket/warped head/bad deck on the block...
#67
i will pull that stud tonight, the water jacket surrounds that hole so i guess it could be cracked or its seeping thru the head gasket. they are copper but it looks like they used sealer around the water jackets
#72
CRAP. had a little water in the oil. was told to try the GM coolant pellets to see if it will seal. i will pick some up today and see what happens.
i was told they see it in about 1 out of 20 blocks that have the threads for the head bolts "studs" have been machined into the coolant area. so my block has two that leak. pass side middle outside the valve cover, drivers side middle inside the valve cover.
im a little freaked out but i will try what AES suggested.
#74
Cool! they have the tablets that say "radiator seal" then the bottle of "block", head gasket seal" i wonder what i should pick?
Yes they did not seem to worried about it.
#80
you will, i like to drive it around,
been working on the base tune, finishing up all the plumbing for the intercooler, the driveshaft is 3.5 .083 tube 1350 solid joints. should handle just about anything,
played with the transbrake. stalled at 4500 and built 7 psi almost as soon as i hit the floor with the gas pedal, the waste gates are not hooked up till i get my Forge UNOS boost controller, it works well on my EVO IX. so i figured what the hell.
i might just take it out sunday for a maiden voyage of logging the computer.
