Injector size input for blown set-up
Old Mar 1, 2004 | 07:19 PM
Wolfee's Avatar
Default Injector size input for blown set-up
Hi there,
I'm new to the blown thing and need some recommendations on what injectors size to go with. I recently bought a set of PP heads/cam and Vortech SC with aftercooler. I would like to know what the best size of injector would be to go with? Could some one please help me out. I will also need a program when I get this thing all together, anyone have any good baselines for LS1 edit? Oh ya, it's for an A4 98 TA. Thank you.
Scott
Old Mar 1, 2004 | 07:37 PM
MECHAM's Avatar
50s with extra room
42s pending how many psi u plan on pushing
Old Mar 1, 2004 | 08:10 PM
BIGBOS's Avatar
What style heads and what cam...
42's should be ok if you don't plan on pushing too much boost.....
Old Mar 1, 2004 | 08:17 PM
Wolfee's Avatar
Cam is 221/224 558 558 114 I believe and the heads are stock LS1 PP. I plan on running 6-9lbs. boost and possibly upgrading the SC in the future. That won't be for quite a while though.
Wolfee
Old Mar 1, 2004 | 09:48 PM
BIGBOS's Avatar
You should get some low comp heads..........6.0L 73cc heads.......that will lower you to under 9.5:1
Old Mar 2, 2004 | 11:59 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
At a minimum you want 42's but you might want to look into 50's.
