What to expect from this setup
Old Jul 27, 2011 | 05:49 PM
Pimp Prix's Avatar
Default What to expect from this setup
I have an 05 GTO with the following mods are 1 7/8" headers, ported manifold, ported TB, formato tune and a vararam intake. I will be installing a V-2 "T" trim Vortech. It has a 28 tooth cog pulley (stock is 30 tooth= 6lbs). I may also get the innovators west overdrive 8" pulley which would add another 1-2 lbs of boost. With 80 lb injectors and a 255lph fuel pump, what kind of power have you guys seen with about 8-10 lbs of boost on a centrifugal blower?
The V-2 T is an upgraded V-1 with helical cut gears for silent operation. Provides 1200 cfm and up to 825hp. (not sure on what type of motor)
