lunati stealth cam
Old Aug 2, 2011 | 05:56 PM
camaro383's Avatar
Default lunati stealth cam
im putting together a 5.3 with my pt88 truck manifold kit, car has a th400 trans
I have a lunati stealth cam specs are 216/221 .507 .510 114
or my custom grind 229/230 .580 .580 115+3
im not sure which one i should run
Old Aug 2, 2011 | 08:38 PM
52172's Avatar
Depends if you want some lope or not? Install the smaller if no. Both will make great power.
Old Aug 2, 2011 | 09:40 PM
camaro383's Avatar
Ya i am kinda thinkin the lunati cam is too small for my setup so.im prob gonna just stick with my custom cam. Im not liking the low lift numbers so much
Old Aug 2, 2011 | 09:42 PM
supersick99z's Avatar
I'd use your custom grind
Old Aug 3, 2011 | 03:40 AM
SB2NOVA's Avatar
Turbo's like higher LSA as well as lift I would definitely go with the custom grind. Besides we always go back for more power this will prevent you from doing it and wishing you wouldve to begin with. Good luck
Old Aug 3, 2011 | 06:57 PM
yonerhottlt1's Avatar
Throw in the custom grind and call it good!
