P1sc-1
Old Aug 2, 2011 | 06:26 PM
GM-boy#5's Avatar
Default P1sc-1
I wanna know how much power can I pull out of a P1SC-1 with out cutting my pistions and blowing my bottom end, a friend of mine said it made 560wrhp
ad 494ftlbs with heads/cam 60lb injectors and a meth kit, and other mods on a sotck bottom end, can a p1 put out yhode kind of numbers?
Old Aug 2, 2011 | 06:57 PM
Packy's Avatar
Some people have made more power but it all depends on supporting mods like FMIC, meth, cam, headers, fuel pumps and the list could go on. With a stock bottom end and exahust manifolds on it you will hardpressed to make much over 500rwhp IMO. Throw some headers, methanol injection, a good pulley combo and fuel pump set-up would put you around if not higher rwhp than where your buddy was with a bit more torque I think.
If you throw some 317 heads on there you can lower the compression a bit and make your stock bottom end a bit more boost friendly. A boost friendly cam will also do wonders for a stock LS1 under pressure.
Old Aug 2, 2011 | 08:25 PM
kwiksilverz28's Avatar
I make 470ish on a mustang dyno at 6100rpms. stock 98 motor heads never been off. Ls6 intake, cam, and headers. Been there for ~4 years. Crane cams had a 98 pushing around 600hp dd... (had disc but...)
Old Aug 3, 2011 | 08:38 AM
GM-boy#5's Avatar
Will the twin intercool set up be enough, or would I need to go bigger?
Old Aug 4, 2011 | 06:38 AM
Bob@BruteSpeed's Avatar
LS1Tech Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
You'll be just fine with the twin intercoolers, especially since you have a methanol injection kit. You'll want to run 100% methanol, as a 50/50 mix tends to put out the flame with forced induction. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Old Aug 4, 2011 | 04:37 PM
jbrenner0188's Avatar
bob what are u saying about 100% meth??never hurd this can u pm me.not to steal the thred
