16lbs on a 2 bar map?
Old Aug 11, 2011 | 05:52 PM
TermnEatr's Avatar
Default 16lbs on a 2 bar map?
Has anyone ran 16 lbs on a 2 bar map withiut issues. also if im going sd and takin my car to a tuner do I need to get a custom OS still say from hptuners or ls1edit or my tuner should be able to do that correct?
Old Aug 11, 2011 | 08:10 PM
WhistlingZ's Avatar
It will be fine, just will run the same spark and fuel at 14.7+ psi.
Old Aug 12, 2011 | 08:11 AM
LS1NOVA's Avatar
Im running 17 on a cobalt 2 bar. Just like WhistlingZ said, it has to use the same spark and fuel as it does at the 14.7 limit.
Old Aug 12, 2011 | 08:35 AM
Vengeance Racing's Avatar
LS1TECH Sponsor
It will work okay.
