5.3L Monte SS
Old Aug 12, 2011 | 06:46 PM
G-Body's Avatar
sawzall wielding director
Default 5.3L Monte SS
I`m in the middle of swapping the 5.3L into my 85 monte carlo SS and I`m trying to decide if its getting turbo`ed or not and if so single or twin.
I want to keep the A/C which really complicates things in this car. None of the exhaust manifolds will clear the A/C suitcase when they are flipped up (to clear the a/c compressor) so it looks like I`m building logs/headers. Thats not an issue.
The issue I`m having now is downpipe size. I had been looking into doing a single master power 70mm. When I started looking at downpipe plumbing it looks like it would be a nightmare to get a 3" downpipe in without it hitting the control arm or melting the a/c suitcase.
If I run dual turbo`s say 55mm could I use 2.5" downpipes? those look like they will easily clear both sides.
I`m not looking to make killer power. I`m keeping a stock motor, maybe adding a ls6 cam. If I had 500-600 at the wheels that would be perfect.
Old Aug 12, 2011 | 10:56 PM
Fbodyjunkie06's Avatar
dual 2.5's should be fine with that size turbo. 500-600 sounds extremely reasonable.
Old Aug 15, 2011 | 04:21 AM
Nic Morales's Avatar
Gbody ******* I know it's off the topic but I'm in the process of doing the same swap to an 88 monte. What motor mounts did you go with and do you like where it placed the motor ?
Old Aug 15, 2011 | 11:37 AM
pdasterly's Avatar
http://youtu.be/5a42z0UbsD8
Old Aug 15, 2011 | 08:57 PM
LS1NOVA's Avatar
You could use oval tubing to get it past the firewall. A single will save some money over twins.
Old Aug 17, 2011 | 12:30 AM
G-Body's Avatar
I love where the mounts placed the motor.....of course I may be biased as I designed and built them myself. I moved the SBC frame side mount back and then made a 1/4" plate upper mount. I will try to remember to take some pics tomorrow.
I moved the lower mount back to clear the a/c compressor (you have to notch the k-member to get it in there). The motor sits with the bellhousing right where the SBC bellhousing was.(you have to remove the rearmost passenger side coil mount boss off the valvecover, trim the coilmount bracket, and notch the heaterbox slightly) The good news is that positioning the engine like that allows a stock f-body oil pan to clear the frame (its tight though, like a 1/4" in some places) It also allows the truck power steering pump and pulley to clear the steering box. I should also have clearance between the alternator and hood, but I haven`t checked that yet.
Old Aug 17, 2011 | 02:56 PM
G-Body's Avatar
I snapped a couple pics of the mounts.
What about fuel pump setup? Is a walbro 255 or an aeromotive 340 stealth enough to feed a 5.3l t70 single turbo motor? Or do I need to step up to twin intank pumps???
Attached Thumbnails 5.3L Monte SS-hpim0930.jpg   5.3L Monte SS-hpim0926.jpg   5.3L Monte SS-hpim0927.jpg   5.3L Monte SS-hpim0929.jpg
