excessive crankcase pressure????
Old Aug 15, 2011 | 04:31 PM
mr_biscuitz's Avatar
Default excessive crankcase pressure????
Engine has about 1500 miles, well did then tore it back down and found the problem for the crazy blow-by, 3 top rings were welded to piston. Car still made good power. Anyways all 8 pistons were replaced with new ones and rings were changed to a total seal gapless ring set for higher boost. Anyways this engine has always had lots of blowby so I was told to try a vaccum pump, so I bought a GRZ motorsports pro series and it helped but Im still having way more than normal. Since the engine has been back together its been to the track once and a few nights of racing elsewhere. Let me know what I should try or what to check? Thank you very much.
Already going to do a leak down and a compression test tonight.
