STS turbo Evap/pcv delete ??s
Old Aug 21, 2011 | 11:02 AM
1sick-Z's Avatar
Default STS turbo Evap/pcv delete ??s
Aside from using this wack harness just to get power to the oil pump could I just vent PCV through an oil/air seperator then to atmosphere, as well as vent the EVAP to atmosphere. Meanwhile just using one automotove relay and hooking power/ground to 12volt ignition on power somewhere and hooking to fuel pump relay pin 87 for trigger to power the oil return pump when the car is on.
I dont see a need to have any of the other parts of the harness if I vent everything to atmosphere and get the pump powered but I know how things can be.
My only other question is what is the purpose of the gold resistor in the wire that goes over the driver shock tower? If I were to make my own single relay/harness to power the oil pump would I have to incorporate this resistor in to get the oil pump to work correctly or is this resistor un-related to the functionality of the oil pump.
Sorry this is alot but I appreciate the help.
Old Aug 21, 2011 | 01:47 PM
mconway68w's Avatar
Vented has been fine for me just run a hose from each valve cover to the inner fender behind the headlights. It's a temp fix until you get cans, but it keeps you from smelling the fumes with the ac on. I used the front port on the passenger vc and the rear pcv port on the driver side.
The gold resistor is for the high/low and it will burn anything it touches. With the pump wired straight to the battery, it runs on high. It's a little loud, but keeps the oil moving faster.
Old Nov 16, 2012 | 02:42 PM
JoshuaGrooms83's Avatar
any news on this? im in the process of doing somthing like this. I was wondering, can one tap into the racetronix hotwire kit to supply power to the oil pump or would this cause too much of a draw and take away from the fuel pump power supply? my original plan was just running my own power lines and a relay to the pump, but for convienence and simplicity sake, using the switching source (key) instead of looking for another (key) source to turn on the oil pump.
Old Feb 26, 2013 | 12:39 PM
i found this. gonna run mine like this. granted its a long tube but it will provide a vacuum to suck out the crack pressure
