Need help Picking Out Procharger for LS1 Miata
mods)
Anyway, I have F-body accessories and I've been looking at a lot of F-body procharger kits and all I can find is complete kits! (comes with D1SC/P1SC and mounting hardware, injectors, fuel pump, intercooler, etc...
I am going to custom do everything but can't seem to find where I can purchase a procharger ONLY set up (hardware and compressor ONLY)
I'm aiming at 550whp at low boost (7-9psi) hopefully it's attainable...
Can anyone help me in the right direction? Thanks a ton!
I don't have much room to work with either...
The motor in the car is staying... I'd love to do what you suggest but will stick to this motor til it grenades...
There is very little room under the hood, so procharger is an easy Solution.
Also.. 550whp is the theoretical limit of my drivetrain (clutch, axles, driveshaft, and fuel system)
I just can't figure out how to buy just the procharger and not the other crap that goes with it...
Why do you say prochargers are unreliable?
To the OP, let me know if you have any questions. Bob
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
first off, why should he ditch his built 346, and go with a 5.3 w/317s? he would be taking steps backwards. nothing wrong with a turbo setup at all, but speaking from a sc standpoint, prochargers are a simple bolt on that can make GREAT power. so many people dd their cars with prochargers on them with no problems what so ever. a D1SC can be pushed to 800wheel, let alone an f series blower........
go f series and never look back.
I get calls from many turbo owners who are fed up with constantly having to deal with problems with their systems. Many people have problems with their turbo mounts cracking over time due to the extreme heat cycles, and others have problems with their oiling systems.
I've sold well over a million dollars dollars worth of ProCharger systems over the years, with very few problems cropping up. Bob
mods)
It looks to me like the Corvette C5/C6 bracket will put the blower in the best location for your project.
http://shop.brutespeed.com/ATI-3GKBB...-3GKBB-006.htm
http://shop.brutespeed.com/ATI-3GKBB...-3GKBB-010.htm
Above are the links for the 8 rib bracket assembly
http://shop.brutespeed.com/ATI-Perfo...-AT-917345.htm
http://shop.brutespeed.com/ATI-3GKMM...-3GKMM-004.htm
You will need this balancer and crank pinning kit
You will need this bypass valve
http://shop.brutespeed.com/ATI-3GPAI...-3GPAI-002.htm
You might be able to use this air inlet and filter assembly
For head unit prices, give me a call. Bob
To the OP depending on your fab skills a turbo kit would be cheaper but if you cant fab it up yourself or dont have the time to it will cost just as much to have someone else fab it up as a procharger in the long run....
D-1SC, no cone
.jpg)
F series has the cones
I don't want to start an argument, but do you know how many people on here have had bearings touch down in there turbos? Bob
Sold my LSXR Intake and N20 already, going to run an LS6 Intake, and a 76 on 10lb's. Have TONS of room behind the diff...
Thanks a ton for the help!
They both go both ways, buy a cog drive for your blower, buy a good turbo. By aster bracket or 10-12rib serpentine or set-up pcv system and oiling system correctly with turbo.
It's all about doing it right the first time and not cheaping out on parts.
Yes, The car now has a Custom Grind Turbo Comp Cam:
.614/.604, 214/210 115LSA
LS6 Intake
Removed the Spray
Buying in a week: Comp Turbo's 76mm, T4 Flange, Un-Divided Housing, Billet Wheel, 0.96 A/R.
80lb Seimens Injectors.
Already Bought:
HKS SSQV Black Edition
Precision 46mm External V-Band Wastegate
Flyin' Miata Big FMIC (Bar & Plate)
Dropping the car off on the 11th of October to True Street in Mckinney for all of the Fab Work (Welding) and Intercooler Piping.
Very Close to having the car ready to be dropped off.
