Single turbo C5 build thread Ok, people keep telling me to do a build thread so here it goes... Car: 1999 C5 Old setup: -LS6 Block -GTP stg 2 heads with bigger valves -Custom ground ED Curtis Cam(big) Full bolt-ons(full exhaust, ls6 intake, vararam, etc) Nic D Tuned - Aprox 430-445whp(never got a final #) New Setup: *ENGINE* -2001 LQ4 Long Block with 317 heads. -Stock pistons and rods with all new bearings. +ARP Rod Bolts and Head studs -Aftermarket Springs and retainers -LS9 Cam -LS9 Headgaskets -LS2 C6 oil pan -Ported Diablo oil pump -LS6 intake -Ported TB *DRIVETRAIN* -McLeod RST twin disc -Monster Slave cylindar OLD stuff being used -Tick Master cylindar -Tick Remote Bleeder -DTE built rear with 342's -DTE rear end brace -300M Half Shafts -LG Solid torque tube bushings -Stock MN12 z06 tranny *TURBO KIT* Turbo kit is being built by AFI Turbo. It will be a nice big single setup forcing air thru the 6 liter! *FUEL* -91 octane -60lb flow matched injectors -Bosch 044 300lph fuel pump The goal is to just use 91 octane and 12-14psi. Obviously it will be Nic D tuned. Im hoping to be around the 650whp mark. Fun times ahead! I'll do my best to update this as I do work and receive parts. Any info/critisism is welcome. |
9 Attachment(s) Ok lets start with taking the old engine out. Attachment 674110 Here is the nasty dirty engine bay. I have ordered some things to clean up the bay and make it look much nicer than before. Attachment 674111 Heres the new LQ4 and its dirty self... Attachment 674112 Attachment 674113 Attachment 674114 Cleaned it up a bit with some brake cleaner and a wire brush mounted on my drill. Attachment 674115 Attachment 674116 Attachment 674117 Attachment 674118 |
2 Attachment(s) Parts that have come in so far are: LS9 Cam LS9 Head Gaskets Dual Gauge pod Bosch 044 fuel pump already mounted properly in a 99 C5 tophat Attachment 674119 Attachment 674120 I am in need of a GOOD machine shop! Any ideas? |
I would seriously consider Upgrading to the rxt over the rst...I know what it's rated for my friend ran one in his 630rw cobra and it started slipping... He upgraded to the rxt and is at 710rw with zero issues I also ran the rxt in my old set up making 730rw with zero issues. They rate their clutches at flywheel hp so while the motors out I'd do it because otherwise later on it's a pain in the ass! |
Subin |
nice more vettes im seeing |
2 Attachment(s) Good luck man looking forward for some pics/vids :D What turbo size ?? Nic D will get you over 700rwhp with safe tune his camaro is nasty. Here is a pic of my single turbo on ZO6 I'm hoping for 680-730rwhp on pump gas and 850+rwhp on race gas/high boost. 347ci ST80 Attachment 674121 Attachment 674122 |
Damn, can't wait to see the final product, How much did that turbo kit cost you from AFI if you don't mind me asking. |
Originally Posted by venom ws7
(Post 15324739)
Originally Posted by OneBadZ0Sick
(Post 15326239)
Have to keep an eye on this one. Good luck :) |
2 Attachment(s) More parts are in! Seimens 60lb Flow Matched Injectors! Attachment 674132 Truck Coils! Obviously will be taken apart and cleaned. Attachment 674133 Block goes to Standard Machine this weekend for some super cleaning and new bearings. |
Subscribed! Should be nice good luck man |
1 Attachment(s) |
Originally Posted by Anti_Venom99
(Post 15353507)
New wheels... http://i1218.photobucket.com/albums/...mydragpack.jpg They will be getting powder coated solid black |
(Post 15353530)
DAMN those are sexy. I am trying to find a set myself. |
(Post 15353664)
There are a few on corvetteforum right now. |
Looking forward to seeing some progress :) |
4 Attachment(s) More parts are in! Diablo ported oil pump Attachment 674135 Attachment 674136 Brand new water pump Attachment 674137 Racetronics LS2 cam timing conversion harness Attachment 674138 |
Update? |
Outdated on turbo kit? |
© 2024 MH Sub I, LLC dba Internet Brands
