Got a few questions guys.
Old Aug 28, 2011 | 10:30 PM
slownova73's Avatar
Default Got a few questions guys.
I searched, and i just dont have time to sort through a crapload of threads.
1. What are some good rings and bearings to go with? also, clearances?
2. I have the rollmaster double roller timing chain, i got it off here, but it didnt come with any oil pump shims,and does it need any type of bearings on the back side? all i got is the sprockets and chain. and i cant find any threads with the info about shimming, so if someone can help me out with that it would be greatly appreciated.
3.Whats a good head gasket to run for just a 3.905 bore? seems the LS9's are popular.
thanks for the help.
Old Aug 29, 2011 | 06:28 PM
LS1NOVA's Avatar
1. I used Speedpro Hellfire, affordable and durable
I think I used .0020 on the mains and .0025 on the rods.
Old Aug 29, 2011 | 06:57 PM
DAVESS02's Avatar
iron or aluminum block?
Old Aug 29, 2011 | 07:22 PM
mpatton's Avatar
Yes run ls9s
Old Aug 29, 2011 | 11:01 PM
slownova73's Avatar
I considered the hellfires but i heard they can wear on yoiur cylinder walls excessively over time because theyre stainless steel. any truth? and ive read between .20-.28 on the rings nad havent found anything on the rods or mains besides what you just said, so atleast i have a starting point, thanks!
iron 5.3 block bored 3.905, 6.125 rods, stock crank
Originally Posted by mpatton
Yes run ls9s
10-4
Old Sep 4, 2011 | 11:21 PM
slownova73's Avatar
ok, bump!
1. machine shop said i need atleast a .55 compressed thickness head gasket. what are the LS9's? i cant seem to find the info, guess im stupid tonight.
2. any info on my question about the rollmaster double roller in my first post?
thanks.
Old Sep 10, 2011 | 01:43 AM
slownova73's Avatar
bump again, i finally found the info on the LS9's, there compressed thickness is .51, which is not enough, i need a minimum of .55, so what is a good gasket to run that wont push water and is suitable for boost?
second, i called around about gettin a hardware kit for the rollmaster, they wont sell it seperate, id have to buy another chain, and still cant find any info on shimming the oil pump for the double roller.
Old Sep 10, 2011 | 10:49 AM
slow67's Avatar
Gingervitis Addict
https://ls1tech.com/forums/generatio...-oil-pump.html
Here ya go.
 Michael S. Palmer
Old Sep 10, 2011 | 05:13 PM
mpatton's Avatar
Why do u need. 55 head gasket. Did u have ur heads milled? If u absulutley have to have that thickness then fine but if its just being recomended and. 51 will work g with ls9. They are 7 layers and work great.
Old Sep 10, 2011 | 08:46 PM
slownova73's Avatar
had the block decked for true-ness since its a turbo build, and my pistons come up slightly over the bore, juts barely, and the machine shop told me that it wont be an issue if i run a .55 head gasket, i trust what they say, since theyre building some of the fastest X275 turbo cars and breaking records, the shop is Harrell Engine & Dyno in denton NC.
