How hot is too hot?
Here is the fix for the 99-02 cars:
https://ls1tech.com/forums/stereo-el...uge-today.html
However, I am not playing with the circuit board. So, with that said. I will just add another gauge I'm running a th350 so the rpm's are up there, but even just cruising around under 3k it got hot. Atleast i'm not the only one, looks like i need to look into a stock stat and i'll definitly be swithching the pushers to pullers on the opposite side, I think this will help keep alot of the heat coming from the engine away from the radiator and help the airflow while driving down the street. Since they're low profile they should fit if i move the radiator up next to the core support, I guess we'll see. If I have to end up cutting the core support out to make room this weekend then we'll just have to make it happen.
I have a tuning laptop that stays in the car for data logging at all times while driving with this setup, I never would have known their was an issue otherwise; temp gauge stays below 210 the whole time.
