12psi problems
Old Sep 4, 2011 | 04:32 PM
pro94lt's Avatar
Default 12psi problems
An old problem has came back. It feels similar to my spark being blowed out. Just seems to stop pulling around 5k it has a newer plugs gapped at .0024k just to eliminate it being
blowed back. Got a 255pump in the tank and just to eliminate fuel pressure I put an old inline pump with no change. I don't know it seems like my inlet could be collapsing anyone bad this prob????
Old Sep 4, 2011 | 08:41 PM
HydroStream6's Avatar
How old are you valve springs, plug wires, and coils?
Old Sep 5, 2011 | 12:40 PM
pro94lt's Avatar
springs were next on my list, wires and coil are new. I had my inlet zip tied tight to keep snug, turns out I had them tight enough they had a slight bow inward allowing it to suck shut, I drilled 2 small holes and ran a zip tie through and secured it so it would not colapse... it's dope but will work till I fab somthing up or just order the plastic inlet from BOB. So those of you wondering if your inlet is colapsing, it just might be...
