garrett 76mm turbo
Old Sep 6, 2011 | 06:13 PM
hdkarmy's Avatar
Default garrett 76mm turbo
I'm doing a 6.0 build and found this turbo new for a great price.($470) What I would like to know is this turbo enough to make 600rwhp with my set up? Or should I sell it and get something different? 6.0, truck manifold, regaped rings, arp studs, ls6 cam? is the A/R to small? what trouble will I run into. Looking to run 12-15psi.
Cold Side:
Compressor Wheel 76mm
.96 a/r
4” Inlet and 2.5” Compressor Outlet
Inducer- 76.71mm
Exducer- 102.36mm
Exhaust Side:
Exhaust Housing T-4 Flanged Divided
A/R sizes - .68
3.0" Vband outlet
Inducer- 74.5mm
Exducer- 60.56mm
Old Sep 6, 2011 | 06:25 PM
ls1ya's Avatar
Is that a real Garrett for 470 new? Where did you get it? Is it an ebay.knockoff
Old Sep 6, 2011 | 08:05 PM
hdkarmy's Avatar
real deal, the guy never even opened the box
Old Sep 7, 2011 | 02:51 AM
stock48's Avatar
9 Second Truck Club
If you build everything for low RPM it might. I made 714 with a 6.0L and TC76 with a .68AR 68mm exh wheel. Peak power came at 4500RPM and was a steady decline from there. Cam was small too. Never dynoed it with the .96 AR but it picked up 3mph at the track.
Old Sep 7, 2011 | 08:28 PM
hdkarmy's Avatar
thanks, would a cam change bring the rpm up or is it the turbo. If the cam, what would you suggest? I would like to peak around 6200.
Old Sep 16, 2011 | 04:15 AM
stock48's Avatar
9 Second Truck Club
It's not the cam it's the turbo. With the .96AR it peaks around 53~5500 RPM.
The same 212@.050 cam and Garret GT76/94mm exh wheel it keeps gaining power to 6200RPM and holds to 6500.
Old Sep 16, 2011 | 07:58 AM
got-a-ls1's Avatar
damn and i am worried about running a .81 on a pt7675 billet on my 5.3 liter.
