Turbo selection. usable 575rwtq target.
I've been looking at 67mm size turbos like the turbonetics hurricane and TC series. But would really like the input of guys running in this power range. Any advice on sizing and a/r combos would be great
Car has a 228r cam and I'm not looking to change that or the heads. Stock bottom.
Thanks in advance for any advice
room to grow is only a minor concern. The small spool gains are exactly what I want to maximize. I've built a 650rw procharged C5 and a turboed rx8. Both were peaky(poor rx8 was gutless until 8k rpm). So I have a very good idea of what I want out of this build. This time its all about the torque. I'm trying to find the right turbo to be dead in the middle of its effeciency map right where I want the power.
If you do a TC67 will probably get you there. If you do have a maximum goal, go with that, as the smaller the turbo the faster the spool (yes, even a few mm will matter, as angular momentum is proportional to the square of the turbo's diameter, which means if you double the size, it takes 4 times longer to get there).
Might want to read a few threads on performancetrucks.net forced induction section (sibling website to ls1tech), as they generally don't turn there motors as hard as f bodies. Example:
http://www.performancetrucks.net/for...cs-vid-488312/
