Bad truboost solenoid?
Im using a 11lbs spring in my tial 38mm gate. Off the spring I see 8 or 9psi. With the truboost at 30% or 90% doesn't make a differance I see 11lbs max.
The car is at the dyno right now and im trying to help diag the issue.
They put direct off the turbo boost to the top wg port and it will boost 16 psi on a quick street run easily. So I'm thinking the solenoid is stuck.
Any one have this issue??
Alex
