cheapest 5.3 turbo setup possible
Old Nov 8, 2017 | 10:12 PM
  #41
Game ova's Avatar
Originally Posted by Chris Davis
Would you mind sharing a parts list with your turbo build. I’m trying to get a list together for my 01 5.3. Never pieced together my own turbo kit but looking at doing so. Thanks in advance
I'm sure that by now, he probably forgot.
Old Nov 9, 2017 | 05:21 AM
  #42
yenkomike's Avatar
built a 5.3 for a buddys Camaro.
2005 5.3 with rings opened up all stock bearings and bolts throughout.
ls9 gaskets and studs.stock 799 heads.
isky triple 12 cam and upgraded stock rockers. all truck assesories intake . t.b.
stock manifolds and I made a 2.5 hot side
$800.00 plug and play microsquirt with deka 80# injectors.
vsracing 88/83 turbo
single eliminator pump on e85.
back half 75 Camaro 3550 lb with driver.
has ran a best of 9.17 @ 147 mph @ 23# boost. has been running for 4 years now with a couple hundred runs at 20 ish # boost
motor was a cheap build but the fuel system and ptc converter cost more than the engine.
Old Nov 9, 2017 | 11:52 AM
  #43
69-chvl's Avatar
Well done sir!!
Old Nov 9, 2017 | 11:59 AM
  #44
JoeNova's Avatar
Restricted User
I've done a $600 single setup, $800 twin setup, and $1500 quad setup.
Its so easy to do these cheap if you have a chop saw, welder, and aren't prejudice against Chinese parts.
