LQ4 or LQ9
Old Sep 30, 2011 | 05:48 AM
Camaro9969's Avatar
Default LQ4 or LQ9
What's better for boost? I have a lq4 in my garage just want to do this right. I hear these motors stock w a Turbo will push out some major HP numbers but only time will tell
Old Sep 30, 2011 | 06:27 AM
buick_lsx's Avatar
both are basically the same, the lower compression will let you run a lil more boost on pump, but the higher compression of the lq9 will help spool the turbo just a lil faster
either one will work lol
Old Sep 30, 2011 | 07:05 AM
hellbents10's Avatar
LS1Tech Sponsor
The LQ9 has better rods unless the LQ4 is a 05' newer engine.
Old Sep 30, 2011 | 09:09 AM
Camaro9969's Avatar
the LQ4 i have is from an 03 Denali i was told. Well both should work well. I hear that even a stock 6.0 will be nasty with a turbo that the bottom ends hold up really well.
Old Oct 16, 2011 | 02:52 AM
dre2013's Avatar
if it really came out of an 03 denali then it is an lq9. the lq9's came in silverado SS's, denalis, and escalades
