BOV opens up as soon as I start the car
As soon as the car cranks up it slams open. I have it t'd into the wastegates that are fed up to my vacuum block.
I'm trying to get a new oring and see if that helps. Any other ideas?
you will get it, just keep asking questions.
I just noticed that the BOV only has one port. Every one that I've seen or owned had two. I disconnected it and it stayed shut. It's definitely not supposed to be open. It's a huge vacuum/boost leak.
With the vacuum hose connected, it sucks that biatch right open. What size spring should I be running in it and does anyone know where to get them and the o-ring replacement.
It will slam shut when you give it some throttle. Won't hurt anything the way it is since you don't build boost at idle
I had 3 springs that came with my jgs, I used the minum combo that kept the BOV closed at highest vacuum to keep dirt/unfiltered air out.
Your non-Synapse BOV is supposed to be closed under cruise vacuum conditions, you change the springs to suit, they usually have directions as such so don't take it from me, contact your BOV manufacturer and they will tell you themselves. The main reason I chose Synapse is their unique approach, full flow within 100 ms instead of the largest freakin guillotine that anyone makes (however fast it decides to respond...).
