Holset Ht60 turbo feed size?
Holset manual says:
"13.The minimum oil pressure when the engine is on load must be 210 kPa (30psi). Maximum permissible operating pressure is 400 kPa (58psi) although 600 kPa (88psi) is permitted during cold start up. Under idling conditions pressure should not fall below 70 kPa (10psi).
14. Recommended oil flows for the turbochargers are 3 litre/min at idle and 3.5 - 4.5 litre/min above maximum torque speed."
->Anyone know what an unrestricted -4an line flows at idle and above max. torque
->anyone know where to buy the fittings for the drain and feed for a holset turbo?
->Do I need a restrictor?
