BOV no noise?
Old Oct 13, 2011 | 01:22 PM
madmax4499's Avatar
if it was me i would drill and tap an 1/8 NPT right in the side of the compressor where you normally see them the casting should be plenty thick to support a 1/8" nipple. or in the intercooler pipe right out of the turbo.
Old Oct 13, 2011 | 01:31 PM
98Z28CobraKiller's Avatar
Restricted User
As mentioned, BOV and WG should not be referenced at the same place. Also, BOV should not be opening at idle or part throttle. WG should be referenced to see only boost. BOV needs to see both boost and vacuum. I thought the RPS BOV was made for them by JGS. You should only hear the BOV on deccel after you've been in boost.
Old Oct 13, 2011 | 02:16 PM
95batmobile's Avatar
ok im gonna drill and tap on my piping right outside of my compressor becuase i dont wanna take everything off again... and will ref. the wastegate there... then ill leave my bov in the location it is now just without the wastegate
Old Oct 13, 2011 | 02:45 PM
madmax4499's Avatar
yep. do that and let me know how it works.
Old Oct 13, 2011 | 04:33 PM
blown head gasket for now... ill post up when its fixed
