Anyone controlling meth with the eboost controller?
Old Oct 12, 2011 | 10:48 AM
Strokinit383's Avatar
Default Anyone controlling meth with the eboost controller?
I recently picked up the eboost controller and plan on doing a few things with it. I'm running the external power to two relays: 1 to turn on my second walbro pump and the other to activate the meth. As soon as I go into boost, both of these should kick on.
I'm thinking I could just pick up the meth pump, wiring and tubing and use my washer fluid tank to hold the meth. I've read that the progressive meth systems really dont make much of a difference for us. Any truth to this? Has anyone done something similar?
Thanks for your input!
Old Oct 13, 2011 | 07:19 AM
Anyone?
Old Oct 13, 2011 | 03:11 PM
stevieturbo's Avatar
And where did you read such bullshit ?
Old Oct 13, 2011 | 08:49 PM
jpracing01's Avatar
The progressive part of meth systems coming from pulsing the ground to the meth pump
Old Oct 14, 2011 | 09:47 AM
So I take it you think otherwise? Please explain.
Old Oct 14, 2011 | 10:19 AM
Myself and the tens of thousands of people using progressive controllers.
how else would you do it ? Just run a switch and dump shitloads in with no metering whatsover ?
Do those same idiots just do the same with their fuel injectors too ?
Old Oct 14, 2011 | 12:10 PM
Haha, hard to say....its good to get some clarification. I was thinking the same, but wanted to verify. Thanks for the input.
Sounds like I will be using the PROGRESSSIVE meth controller.
