cam for MP 122 maggie
Old Oct 15, 2011 | 10:15 AM
supershift67's Avatar
Default cam for MP 122 maggie
I have a patriot performance cam for my lq4 and was wondering if it will work o.k. with the magnacharger, I would like to use since I already have it but if the stock cam would work better I would just leave the cam change for later. tha cam specs are 225/229 and 580 590. I believe on a 114.
Old Oct 15, 2011 | 03:42 PM
MJD's Avatar
MJD
That cam's fine. Leave it in and good luck with the build.
Old Oct 15, 2011 | 10:41 PM
Chris'stransam's Avatar
Maggie only good for about 600 max . Any thing over that , it becomes a heat pump
Old Oct 16, 2011 | 08:16 AM
old motorhead's Avatar
You might experience a little rotor knock with that cam . Otherwise, if you like how it behaves, it will be fine with that MP122. The boost will come in super quick on a 6.0L. You won't have any sogginess on the bottom end.
Old Oct 16, 2011 | 07:41 PM
thanks for the input guys. I will give it a try.
