Shopping List for 2000 C5
Old Oct 17, 2011 | 08:32 PM
tb30570's Avatar
Default Shopping List for 2000 C5
Winter is coming. I'm ready to buy a S/C kit. Here is my shopping list. Am I missing anything or is anything on the list wrong?
A&A 10psi S/C Kit.....................................$5495
Comp Cams 26921-KIT (springs)..................$549
Devil's'Own 5106 DVC-30 Stage 2.................$375
Dyno Tune.............................................. .$400
alternator power steering bracket 12578068...$60
160 degree thermostat...............................$40
NGK TR-6 spark plugs.................................$20
Total............................................. ..........$6939
Old Oct 17, 2011 | 10:04 PM
SPRAYED 01's Avatar
What else is already done to the car? Do you want to do headers or a stall if auto before the tune?
Old Oct 18, 2011 | 04:15 PM
tb30570's Avatar
already have long tubes installed w/o cats. 6-speed, no torque converter.
Old Oct 18, 2011 | 04:35 PM
JAX04's Avatar
Fuel system?
Old Oct 18, 2011 | 04:37 PM
chris@hps's Avatar
Pin the crank,Injectors, Fuel Pump,Clutch(maybe),Flip Drive Kit, and make sure you have it street tuned as well as dyno tuned.
Chris
tb30570's Avatar
Originally Posted by JAX04
Fuel system?
the A&A kit comes with a boost-a-pump and injectors
Old Oct 18, 2011 | 04:48 PM
tb30570's Avatar
Chris
-pinning kit
-injectors
-boost-a-pump
-all brackets and belts required
I'll replace the clutch when it dies.
There is only one place where I live that does tuning. I had them do a dyno tune on my other car. What do they do for a street tune? 1/4 mile?
Old Oct 19, 2011 | 08:45 AM
chris@hps's Avatar
-pinning kit
-injectors
-boost-a-pump
A street tune consist of actually tuning the VE Tables and Maf tables along while logging with a WB02. Not just WOT on a dyno.
Chris
Old Oct 19, 2011 | 08:23 PM
tb30570's Avatar
I'm going to have the local tuning shop quote turn key just to see how much more it costs. How much is a fair price for turn-key? $9000?
Old Oct 19, 2011 | 09:12 PM
Louis's Avatar
Thats about right. Id pull the front timing cover, and loctite the front cam gear bolts. On stock LSx cars, they will come loose.
Old Oct 20, 2011 | 05:43 PM
tb30570's Avatar
The local speed shop quoted about $8600 for turn key. They quoted with an AEM meth kit rather than a Devil's'Own (either one is fine with me).
They told me I don't need Meth/Water for 10psi of boost (see below).
"I HIGHLY recommend eliminating the water/meth system. It is not necessary to achieve 10lbs of boost safely and we have done many Spercharger and Turbo installs with excellent results."
My other car is running about 15psi of boost and I have a terrible time keeping the IAT2 low in the summer time.
What do you think about not using a Meth/Water kit? The extra cost doesn't seem like much to me if it makes a big difference to the IAT2.
Old Oct 20, 2011 | 05:52 PM
Bob@BruteSpeed's Avatar
LS1Tech Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
My other car is running about 15psi of boost and I have a terrible time keeping the AIT2 low in the summer time.
What do you think about not using a Meth/Water kit? The extra cost doesn't seem like much to me if it makes a big difference to the AIT2.
When running methanol with boost, I recommend using 100% methanol. The water in a mix tends to put the flame out under boost. Inlet air temps typically drop 35 to 40 degrees when the meth kicks in, I can't see any reason not to use it at 10 psi. I wouldn't throw extra timing into the tune because of the meth, you can but if the meth quits it can cause expensive engine problems. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Old Oct 20, 2011 | 05:54 PM
LS1Tech Sponsor
FYI: The NGK TR6 pn# 4177 plugs should only cost you $2 something a piece. Bob
__________________
Old Oct 20, 2011 | 07:40 PM
allout06's Avatar
mike norris tuned my car all on the dyno, he did the VE tables all on the dyno.... my BOV was causing problems with my MAF, so he unplugged it and tuned around it until i could relocate the BOV, and my car drives great... so...
Plan to spend more than $400 for a forced induction tune... most ive seen are around $5-$700
2-bar map sensor - $60-$90 part number: 12615136 from GM
how about gauges? wideband, fuel pressure, boost/vacuum? $350-500
Old Oct 21, 2011 | 10:18 AM
Louis's Avatar
x2 on meth, if you can afford it, its ALWAYS a nice safety feature.
